And another one... I can change the mid classes for the products and the listview in the theme settings but not for the cart. The whole cart uses fullscreen. Where can I do this changes?
Ok, the product lists appearance is the setting also for the cart page... I want the shop in fullwidth and the cart in centered fixed width. How can I do this?
Version with updated theme is available on themeForest.
CFP said: Ok, the product lists appearance is the setting also for the cart page
Yes, this minor pages inherit setting of main page shop. There is no option for it to change specially for cart, as we didn't want to add options that would be almost never used and we kept this in design decision.
If you need this go to photon-a13\advance\utilities\custom.php line~203 and before this :
Ok your right. Strange thing. I had saved the file with a "_" at the beginning. Now, I do not know why, with the update I transfer this file. And then it does not work anymore. So I deleted this one and it works like it should. THX
Sure, updated to WC rolled out few hours ago as we ended our work day already. I will get right to it to see what they changed.
Version with updated theme is available on themeForest. Yes, this minor pages inherit setting of main page shop. There is no option for it to change specially for cart, as we didn't want to add options that would be almost never used and we kept this in design decision.
If you need this go to photon-a13\advance\utilities\custom.php line~203 and before this : add this: With kind regards.
How can I change it to get it right?
http://www.xoluxurywheels.com/shop/ - Items are separated
http://www.xoluxurywheels.com/shop/xo-luxury-wheel-cap/ - Description is not side by side with product image but below
PS. Please don't hijack topics:-)
