Layout missing
in Fame Posts: 119
Hi my friend,
I do have a new layout problem after the last updates...
I lost all my set layout on home page of www.italiaamoremio.it as you can see in the screenshot attached.
Same goes with shop page where it displays only 2 pics in a row instead of 3.
How can I fix it?
Regards
Gabriele
    Hey.. problem solved...
    The plugin W3 Total Cache probably is not compatible with the new release of wordpress or your theme.
    I remembered I've installed this plugin and the problem in the website is the pics size...
    So I found the problem..
    Any suggestion for speed up the website?
    Ciao
    Great you have solved it.
    Speed of page is wide topic, so there is no short answer.
    In your case and W3TC it might be some wrong order on caching CSS or something else, hard to say now. Experiment with different options of this plugin.
