Hi, My icons appears very small and not centered neither in the cercles or the boxs. I tried to change the configuration , but it's not working Please see pictures attached. Thank you
I tried the CSS but it didn't work What I don't understand is that on some pages (with a different layout) it works fine http://howmuchistheentrance.com/landmark/eiffel-tower/ Also, I don't know how to update the theme properly (somebody did it for me last time)
OK I see, now that update didn't help for this issue, but custom CSS finally kicked in, and it is fixing this case. I will fix it for next version. Thanks for pointing this out!
Maybe you used some minfication plugin or it is other plugin conflict.
Please show link to your site.
I did not used any plugin.It happened when I updated the theme
Here is the link: http://howmuchistheentrance.com/eiffel-tower-entrance-fees/
You can try to update theme to newest version, as it looks like it works fine in 1.5.0
OR you can put this in custom CSS: With kind regards.
http://apollo13.eu/docs/blame/#!/modification_of_theme_custom_css
About update: http://apollo13.eu/docs/blame/#!/installation_update_update_theme On this page VC didn't put his styles, that is why.
(Blame - Custom CSS )
.wc-header-cart.empty-cart .cart-link, #header .search .action.open {color:#000000;}
.title-icon {
line-height: 90px !important;
font-size: 30px !important;
