I recently noticed this feature. Its great. However, when it comes to "variable products" linked to an album item, it shows "Select Options" instead of "Add to Cart" or "Buy Now" or whatever. Is there a way to customize the button label that it creates on this feature?
romeofotowv said: when it comes to "variable products" linked to an album item, it shows "Select Options" instead of "Add to Cart" or "Buy Now" or whatever.
It is native to woocommerce button. So if you can solve it for woocommerce then you can solve it also here:-) But you can't solve it:-) Cause why did you create variable product in first place? Cause you wanted user to choose some options:-)
So you have to decide if you are making few similar products with different parameters or one with options to select.
This has nothing to do with theme, but lot with organization of your site.
While editing images in Album you have to select product which it refers to, see screen below:
Perfect
It works
Thank you very much
Hope it is clear now:-)
