Hi my friend...
I made the last update of Fame and I have problems with visual composer..
For istance in the "Woocommerce product category" or The Woocommerce product" it displays only 1 or 2 products instead of the 3 that i set in the homepage field..
Have you ever seen it?
Website www.italiaamoremio.it
It's not working on twenty fifteen as well... :-(
if you have time to check on my dashboard you should already have the account details... :-)
i do have several categories... And for example for wines I have
- wine - red wines - pala
- wine - white wines - pala
- wine - rosè wines - pala
Now the vc Woocommerce Product categories is not displaying all categories but only for istance the rosè one of Pala.. And I have only two bottles on this category...
For this reason the page display only 2 bottles instead of the three I'm asking...
Now.. My question is... Is there a way to ask to vc to display all categories so I can have the way to choise at least the category with more wines?
i hope you understood what I meant..
Gabriele
Hi Gabriele,
The issue is because there is an inbuilt version of Visual Composer (or the related code) present in your theme which is overriding the standalone plugin version and hence causing the issue. You will have to get rid of it. I would advise you to do so with the help of theme author, otherwise you might loose the extra elements added by him. Once this is done, you can install the standalone plugin and it will work fine. Kindly check.
Thank you,
Hi Rohan,
the problem was present even before the installation of the standalone plugin... for this reason I bought your plugin directly and hoped the problem would have solved...
Instead I have the same problem...
Hi Info@eventikatravel.it,
Yes I understand, but the "product category" element at your end is modified by the theme author and hence it is causing the issue. When you install the standalone plugin, the inbuilt code from the theme is overriding it and hence rendering it as in-effective. hence we recommend you to get rid of the inbuilt code which is present, so that standalone version can work fine at your end. I hope this explains it in a better way.
Thank you,
Can you do anything about it?
Thanks for these report. If I understand them right, we have to remove theme extension for Visual Composer, that added functionality for WooCommerece(that is big connection of things :-) ). Now that VC added such shortcodes, they may come in conflict I guess. But you said you had same issue on default Wordpress theme, right?
Anyway lets try to remove it:
Go to fame\advance\plugins\js_composer_mod\config.php line ~1184 and remove everything from this code till end of file Remove also this mentioned code - Everything since Woocommerce comment:-)
If that won't help then issue is somewhere else.
Tell me later how it went.
I'm explainging..
It takes all categories now (white and ALL subcategories, rosè and ALL subcatergorries) but not the red wines...
For istance I do have wine categories as follow:
- white wines - sardinia - pala
- rosè wines - sardinia - pala
- red wines - sardinia ..... then it doesn't show the rest of sardinia category (it displays only the first 2 subcategories and not the 3 as in the other categories).
any idea???
Please try it.
If it wont help then maybe best would be to return to earlier version of VC.
Now I've deleted the element and when trying to rewrite it again the icons with chart are all disappeared...
see my screenshot..
Icons with chart? I am getting lost here:-) Have you activated all VC elements as explained here http://apollo13.eu/docs/fame/#!/activate_builder_options ?
Then try last version that worked for you. However it seems very strange that you have such issues. Do you have old theme version to use it?
I'm uploading the old files and let you knw if they will work... :-)
I installed even the version of last august, but I have always the same problem.
Maybe I didn't notice it as I wasn't using that VC elements...
I'm reinstalling your new release...
If you can find a solution it will be very appreciated..
I read all topic again, and I am now not sure where it exactly breaks for you. Can you show me on screen shot + link to that site where it exactly returns wrong products?
PS. I am sorry that you have to experience so many annoying things with your site.
I'm sending you two screenshot... the first (the one without number) is the screenshot of the vc element (woocommerce product category) and you can see that the category of red wines are just the regions without subcategories.
The second one (the one with _1) is the categorie I've in the website (you can also check them on www.italiaamoremio.it)
As you can see in the red wines I have many subcategories that are not displayed in the vc element... in the italian part is even worst as I do not have many categories...
I am thinking about it cause you have 330 categories per language.
