Dear Air - I noticed today that my social icons are not showing on Chrome even though they are showing on Safari. That's quite strange right? Also is there a way to customize a social icon - I use "The Knot" service which is a big deal in wedding industry. My site is www.jakemillerphoto.com
Again hidden question in one topic.
There is special last field in social settings, named "Custom", you can enter there your link.
If you need to change image for it then add this custom CSS with your image in it. With kind regards.
Please explain to me where I find this "Custom" field in social settings and where the CSS would go; into the Custom CSS widget you've provided with the theme or right into the URL link filed in socials?
Please be thorough in your explanation so we can resolve this quickly. Thank you.
I see on your screen shot that you don't see social icons on left of inputs. Or is it just cut screen shot?
See my screen shot:
As for custom CSS you insert it in custom CSS :-) Input you ask about is only for your link.
PS. What theme version do you use?
If you really need to put there "this service" icon, then you can edit social icons image and instead of this "small arrow"(that is by default displayed for custom social), put there what you like. In your case it will be file located in photon-a13/images/socials.png - there you can edit its all three states(colors).
Now that I think, same way you can achieve your three custom social services. Just edit icons of services that you will not use.
