How do I get "sale" "out of stock" and "new" ribbon?
edited June 2014 in Fame Posts: 2
I'm just wondering where do I get this kind of ribbon. I don't see any option on "add product" of woommerce that I can add this kind of ribbon.
Please help.
Thanks,
Doreen
    Hello
    Add tag 'new' to product and you will get New ribbon.
    Others will show up when product is on sale or out of stock - just like name says:-)
  • Hello,
    I try to add tag "new arrival" it doesn't show up. Can you give full instruction on how to do that?
    Thanks.
    But this is full instruction :-) Just add 'new' tag, nothing more.
    Check screen shot, and I will update documentation soon.
    Hope that helps.
    800 x 600 - 43K
  • Hi Air, this is just to say thanks for the above explanation - I had the same problem (how to activate ribbons), searched the Fame forum, found your very clear answer, perfect!
    I am glad you have found it useful! :-)
