Change wording for works filter
I'm having a little of a hard time finding how to change the wording "all categories" used by default to filter my different work.
Do you know how I could change that?
Thanks a lot, see you soon!
    this sentence is within 'Visual Composer extend by Apollo13 for Chillout' plugin.
    If your website needs translation (You don't want it to be in English) - just translate this plugin.
    If You can perform small code change - please navigate to ..\wp-content\plugins\vc_extend_apollo13_chillout\a13_shortcodes.php file, line no. is about 840, find 'All categories' and change this sentence to whatever You want.
  • Hey,
    sorry for the delay.
    Thank you very much, works perfectly by going in the php file!
    Cheers,
    Quentin
