Helpppp.... Website a mess
in Fame Posts: 119
Hi my friend, I have the website in this situation and cannot understand even why...
Www.italiaamoremio.it
I'm uploading what I see if I'm not logged in... If I enter from wp dashboard it works fine...
Please helppppppp...
Gabriele
    I see you use some default Wordpress theme now. Did you install some optimization plugins lately?
    Hi.. I actually didn't do anything since last time it was working fine... I opted today to delete everythind and try to restore everything...
    I'll let you know...
    Then maybe there were something else happening on server. Keep me informed.
    I have this problem in installing your theme's plugins... can you understand why?
    1366 x 768 - 273K
    edited February 2016 Posts: 10,970
    It looks something changed in your server configuration. Maybe some safety mechanisms. You will have to install these plugins manually -> http://support.apollo13.eu/discussion/2390/fame-updates-install-required-plugins
    Hi my friend.. I found out what the problem was.
    It was the WP Rocket plug-in and the minification and concatenation process.
    It has meesed up all the website.
    That what I asked about in first answer:-) Great you have solved it.
