Hi there,
I noticed if someone clicks on a Team member picture, or a picture from the "works" section, it enlarges into a full page slider. But once you're done with the slider, there's no "x" out option to go back to the site. Is that something can be customized or added on our own?
Thank you!
And I am having some difficulty in getting the "works" to look similar to the demo site.
Can You please provide some screenshots of what's the problem?
And also, I'm having difficultly getting my Works shortcode to look similar to the Chill out demo. How can I get the featured image to be on the top, with content in the middle, and "Similar works" with photos beneath?
Appreciate your help!
While editing work item - find 'Layout mode of single work in works list.' and set it to 'Info box over the image'
as for similar works section: this is odd, but somehow this is off, I'm quite sure it's because some tests have been performed and the code hasn't been cleaned. So we'll fix that in upcoming update.
In order to do the quick_fix for You - I need a login credentials to admin panel. If You can send me those - please do it via private message.
Please log-in and do the quick fix. I'm private messaging you now.
Also, I can't get our Team short code to work properly either. I've attached a layout that we want (it's similar to the Chill out demo) and when editing the short code in visual composer, I am not seeing how I'm able to do this?
edit each item people item You want to display by Team shortcode, change the 'Item size in grid view' parameter ( the small items on your design are of size 1x1, and the wide one is 3x1). As for ordering those items - use 'Order by' and 'Order way' parameters in Team shortcode edit panel.
