is there anyway to change the colors of the text? (beta.evolve-group.com, then click reach us) I've tried a few different CSS coding, but none seem to work for me. Maybe I'm not putting the code in the right area?
I mean the entire form design in our Reach Us section. Is there a way to change the color of the font, like "First Name" "Last Name" "Email Address"? See the screenshot I attached, if that helps.
Also, and this isbe a separate issue, but on the Chillout typography options, I changed all font colors to be #455560, which is our branding colors, but certain headings are remaining black.
If you take a look at Our Blog (beta.evolve-group.com/ourblog), you'll see the title of the blog posts are #000000. Is there anyway I can change this?
