Hi, the footer content on mobile devices (more on landscape) stops before I can see all information. If you wanna take a look: http://www.friedsamphotography.com
That will fix it but not on the iPhone in Landscape mode. In landscape mode now you can't close the footer anymore because the button is now out of range.
Works fine for me.
What browser, what screen resolution?
Thanks for report.
I think best solution will be to remove max-height from footer.
Use such custom CSS: I think I will also add this to theme.
