My video background has some part disappear
in Thirteen Posts: 6
As you can see on the attach file ,I am using video background by another plugin for my hosted video
here the url :www.norththai-tours.com
but my video has some part disappear, i mean it is not well shape as i set by the row separator (on massive add ons plugin)
which is compatible with visual composer.
    edited May 2016 Posts: 10,970
    I don't see your video when I view the page, either on firefox or on Chrome. Anyway try putting there some backround image, or background color. Check if same issue will appear. If yes then, please also try switching to default WordPress theme, and check how it is displayed there. After this please report back.
