I tried to create a new page using the Cevee theme :
http://edgemargueritte.xyz/test-21/ However I don't manage to get the same look as the one observed on the "shortcode" example page:
http://edgemargueritte.xyz/shortcodes/ (ie: the scrolling block with white background).
I managed to somehow replicate it here by adding some CSS classes:
http://edgemargueritte.xyz/kurenai-tennyo-fanfiction-naruto/ However this not a very clean solution and I don't get how it is achieved in the "shortcode" page.
Could you provide me with some explainations?
Thank you very much.
What is a problem? This page looks good but has poor content. Do You have problems using Visual Composer?
Is there an error?
You'll not get scrolling unless the content will take more space.
This really does not look like the provided http://edgemargueritte.xyz/shortcodes/ page
I just created a new page, chose Visual Editor and added blocks.
please edit row, select tab 'General' and change the background color to white.
