I am unable to add Arabic custom font, it is always overwritten by the page setting, I want this font just to be used for the Arabic website without affecting the English one ! please help
hi, I changed the font family in the RTL css file then I discoverd that the RTL css file is not loaded ,so I add the css code in the custome css for the each page for visual composer,, it didt work, . when I inspect the elements , I can clerly see that it is taknig the font from the component setting, so if I remove that line on the runtime it is working , now how I can force it to take the font in the css file , or at least to add the custom font to the composer component
Well as I remember you have to add definitions for custom fonts at start of CSS file, so In this case I would rather add definitions in style.css(best in child theme if you use it) on the beginning, and then use them with custom CSS.
Thanks for your quick response and thats what I did, but the things is it is overwriting font family by the default font from the visual composer, and in the visual composer there is no place to add my font.
Hi, this is my staging link : http://bloozar.com/ please click on the Arabic Language link, I did the changes on the main Style.css file and also to the RTL.css file , but still it is overwriting the css by the one generated by visual composer.
I would like to add the custom font just for the Arabic version, the English version is fine. please try to add any custom Arabic font , my defined font called : ge_thameenbook
You thought that all definitions of font-family are in style.css and you updated all that were there, but most important are in user.css http://bloozar.com/wp-content/themes/thirteen/user/user.css?ver=1.0.8 This file is generated so don't edit it, but overwrite its rules in custom CSS field.
I am off for weekend, however try using body.rtl or html[lang="ar"] selector for this styles that should have this style - it should be enough for your site. Just prepend styles you add to custom CSS with one of these.
Please tell me what you have exactly done until now to make it happen, so I could guess were exactly is the issue.
So:
style.css Hope this gives you some hints.
font-family
are in style.css and you updated all that were there, but most important are in user.css http://bloozar.com/wp-content/themes/thirteen/user/user.css?ver=1.0.8This file is generated so don't edit it, but overwrite its rules in custom CSS field.
Hope you can make it now.
I don't want to affect the English Language font also.
how I can do that
body.rtl
orhtml[lang="ar"]
selector for this styles that should have this style - it should be enough for your site.Just prepend styles you add to custom CSS with one of these.
