Missing Files
in Fame Posts: 4
We're having a problem our single product page, since woocommerce updated the dropdown and text area have dissapoeared.
We're being told to update woocommerce files, however when we have downloaded them from themeforest the latest versions aren't there (See screenshots for missing files).
Can anyone advise?
Jonnyimage
    edited June 2016 Posts: 10,970
    As for review.php file I don't know form where you have it cause it is not added to our theme, so it would be best to remove it(unless you added it by yourself).
    As for other file try two attachments from this topic, however we will also release update today so you can wait for it.
    williammay said: We're having a problem our single product page, since woocommerce updated the dropdown and text area have dissapoeared.
    From what you write only "review" part can fix your issue.
  • Thanks a lot for that, i will wait for the new update to be released.
    The review.php must have been part of your template files as we haven't customised them.
    Jonny
