Hi
I have add a page named HOME, i ve set it up as first page and selected the page with slider template. the problem is that the title HOME is not dissapearing and the slider is not 100% fullscreen. As you can see in the atached picture.
Please guide me to achieve the desired options (fullscreen with no title) check www.antimetil.be to see what i mean
thank you!
You have to choose slider as front-page in theme settings to make it work http://apollo13.eu/docs/beach/#!/main_settings_menu_what_to_show_on_front_page
As you can see on attached files, i've done as you said but the title is still there! And anyway, there is that big GAP from "acasa/home" to actual slide
