Header Menu Issues
I am having a difficult time customizing the header and menu options. How do I get rid of the black button on the 2nd slider on the homepage. (attached image). Also how do I remove the extra hamburger menu. And as for the menu drop downs how can I have them drop down automatically from hovering and make them thinner?
www.dummyalpinevapor.com
  • Also, the "sign in" button goes nowhere. I don't see a page in the backend that is for signing up.
    Hi there:-)
    You page is in maintenance mode so I can't verify now.
    alpinevapor said: And as for the menu drop downs how can I have them drop down automatically from hovering and make them thinner?
    There is no option to do that. We chosen "click to open" variant as it is mobile friendly.
    alpinevapor said: How do I get rid of the black button on the 2nd slider on the homepage
    Do you want to change color or remove button? If change color then depending on header color variant you should chanage it there.
    alpinevapor said: Also how do I remove the extra hamburger menu
    This is probably menu overlay disable it in-> http://apollo13.eu/docs/fatmoon/#!/header_menu_overlay
    alpinevapor said: Also, the "sign in" button goes nowhere. I don't see a page in the backend that is for signing up.
    You choose link where it should lead -> http://apollo13.eu/docs/fatmoon/#!/header_tools
    Hi there,
    Issue with installing Hope theme.
    To reproduce:
    1. Install Hope theme demo data fresh install
    2. Upload new logo and try changing it from Hope > new logo
    3. New logo changes in Customize, but on save, Hope logo still appears every time!
    UPDATED:
    1. If I then delete the logo from Media, and try selecting my logo again, logo isn't updated!
    1630 x 1400 - 195K
    Make sure you changed logo in light and dark variants also, cause this demo is using them http://apollo13.eu/docs/fatmoon/#!/header_variant_light_dark
    If you are happy with this theme please don't forget to rate us on ThemeForest - it helps us a lot! Thanks! How to rate?
