hi!
i've some problem about responsive in mobile.
in web, its normal :
http://image.prntscr.com/image/d6bf675dc91d4d508bebd09d2b0e15aa.pngbut in mobile its so bad:
http://image.prntscr.com/image/f96b88b73bae4c7cbbf46c9f07b32698.pngmy web site: www.terapium.com
i created it with "work"
i tried somethink about marigins and other think but i cant fix it. there are so many empty space between that blocks. Need help.
Thank you.
are those elements a blog posts? or some kind of static information on your website?
You have this effect because you did not provide images for those elements.
I must use image for that box?
