Hi there
I still love your theme but in displaying my works (portfolio > single work) I'd like to have my text above the media (and below the page title) instead of having (in my case bricks album) the text below. Also I'd rather use my own titles instead of displaying the page title (when inactivating title bar eveything slides up and layout is ugly). And when using borders for the layout the works nav creates a gap whicht I'd like not to have. Can you help?
Thanks, Pascal
You are asking here many questions but lets try to handle them somehow. You have option to disable title bar in each work in "Title bar settings". You can also disable it for all Works in Customizing ▸ Works settings ▸ Single work - title bar
Borders cover whole page layout - that is how they work. I don't understand your issue here. You can always switch off border layout in theme settings -> http://apollo13.eu/docs/fatmoon/#!/general_layout
I don't know what result will it give but you can try such thing:
Go to fatmoon\single-work.php line ~135 and cut out this code:
<?php a13fatmoon_single_work_text_content($content); ?>
Paste it in same file but line ~23 just below With kind regards.
You said: You have option to disable title bar in each work in "Title bar settings". You can also disable it for all Works in Customizing ▸ Works settings ▸ Single work - title bar
> Yes but as written before this means that the whole page slides toward the top. I'd just like not to display the title but keept the top padding as it is so far
You said: Borders cover whole page layout - that is how they work. I don't understand your issue here. You can always switch off border layout in theme settings -> http://apollo13.eu/docs/fatmoon/#!/general_layout
Yes but I'd like to have borders in my content and have the work nav full width
For the text above the media. Thanks for you code. Is there a way to code this into child theme. Else I am going to loose my layout with every update.
Thanks a lot
Pascal
That is custom design wish if I understand you right. However you can disable side borders if you like. You can choose which borders should be added to layout.
So title bar, but no title? You can hide it with custom CSS: With kind regards.
I just tried out the php change (as this is the most important for me) but it just cuts out the text but doesn't place it above the media.. did I do something wrong?
Thnks .. now it works.. but it does seem to affect the settings for title bar? Wether I disable or change settings it doesn't affect anything (see screenshots)
Remove line ~36:
$content = apply_filters( 'the_content', get_the_content() );
Remove line ~135:
<?php apollo13framework_single_work_text_content($content); ?>
Under line ~21 paste above removed lines, so whole change would look like: With kind regards.
Pascal
