remove header from blog page, and turn off load more at footer.
Hi there,
I'm trying to use the blog page in Brooklyn as my Portfolio page. I like the way my videos layout in the 3 column view. The only issue is that I'd love to turn of the header portion. Is this possible? I've attached an image to show where I mean. It's the section outlined in Pink that says portfolio.
Also, I want to turn off the footer that says "load more". There are only 2 more videos and they fit on the page perfectly. The load more makes me have 2 spaces that are left unfilled, as shown in the second image. Thanks so much!
Greg Tuzin
    Hi there:-)
    tuzin said: The only issue is that I'd love to turn of the header portion
    Turn off title bar for blog : Customizing ▸ Blog settings ▸ Posts list - title bar
    tuzin said: Also, I want to turn off the footer that says "load more".
    You can turn it off in blog settings : Customizing ▸ Blog settings ▸ Posts list ▸ Lazy load
    http://apollo13.eu/docs/apollo13_framework_theme/#!/blog_menu
  • Thanks. That's great. I did both. The first worked perfectly. The Lazy Load got me part way there. I've attached an image to show what it does now. Can I get all of my videos to fit on one page, and not have to click on a second page? There are just 2 more videos to fit, and they should fit perfectly. Thanks again.
    Greg
    1405 x 562 - 250K
    Yes, just set bigger "Blog pages show at most" -> https://codex.wordpress.org/Settings_Reading_Screen
