Header indicator color is ok in idle mode: black "i" on custom color background. However on hover, it looks it wants to invert that but instead it goes to black background and default theme color "i". Where can I change that to my custom color?
Thanks.
If you could post link to your site it would help much.
So you want to change hover color to same color that is when "non-hovering"?
You can work with such custom CSS: With kind regards.
My site is not online yet. Still maintenance mode.
The header indicator takes its color from the one you set on "Main settings". In my case this one:
It took my custom color automatically when I set it.
However when you hover over it, the color of the "i" is the color you set on your demo and not my custom color:
That is why I think it should take my custom one automatically as well.
Anyway, I will try with that css.
Thanks.
When you post a new message on footer and the indicator blinks slowly, it happens the same: when the background turns to black (in my case), the "i" turns to demo color. Only when slow blinking now. (https://www.elimaginario.es). How can I fix that?
Regards.
Let try with this custom CSS: In both rules change to same colors, as one of them is for older devices. These are rules for animation.
This code works, but i can't change this code (below) without changing color throughout the site.
Can you help me? I want to change color only for footer-msg-indicator.
Thank you.
I am not sure what you mean, cause CSS you have posted only works for this indicator. What else it changes for you? Can you show me link?
Regards.
