Basically what I would like to achieve is an oversight of my work at the end of each of my projects like below http://bumsch.com/work/flat-ul-kit/ (Link is based on an work item in flatmoon)
Yes, album design is different then Works design so you won't be able to achieve same thing.
If you achieved what you like with Works, then you should use it. If you need to separate two lists of works, then you should use Categories for Works.
Is there any way I can delete the "previous and next" icon at the bottom of a work item and make the bottom part black like the footer? http://bumsch.com/work/flat-ul-kit/
Well this is not what you said :-) You wanted to paint it black. Anyway go to "Customizing ▸ Works settings ▸ Single work ▸Works navigation" and disable it.
But I would like to have the design look like this
http://bumsch.com/album/gallery2/
(Link is based on an album item in flatmoon)
You can enable Visual Composer for albums in its settings if that is what you are asking about :-)
See screen shot:
Basically I would like to have this design (with little menu overview icon at the top)
But with an overview (postgrid)of all albums/jobs at the bottom, like this
But when I try to use the postgrid do do that it places the images under the body copy but not right above the footer, see attachment.
about SVG - not tested, please try it:-)
see attachment.
Try such custom CSS: With kind regards.
I am getting closer and closer to where I want to be. I have two more questions.
Can you tell me where I can adjust the titles that are shown on the bricks
both here:
http://bumsch.com
and for instance here:
http://bumsch.com/work/book-mockup-2/
also...
The postgrid elements the bottom of the page
see here:
For web it goes from 4 to 1 grid elements per row and for mobile its always 1 grid elements per row.
Can I change these settings somewhere?
Thx!
see link and attachment.
Cheers!
Daniel will soon reply on your other question. For future please separate different questions to different topics.
Boxed edition
by alex warden
I Know where to change the text, but where can I change the size and font?
Will start making different topics.
