Hi there!
The postgrid elements the bottom of the page
see here:
http://bumsch.com/work/book-mockup-2/For web it goes from 4 to 1 grid elements per row.
For mobile its always 1 grid elements per row.
Can I change these settings somewhere?
Thx!
Vincent
this can be achieved only by altering css styles.
use definition:
.vc_col-sm-3 { display: inline-block !important; width: 25% !important; }
That worked brilliantly! Cheers!
Can you do the same for mobile? it's now on one column.
I would prefer for it to be on two columns. Would that be possible?
Kind regards,
Vincent
Is there any way I could have it on two columns for my mobile phone?
you need to wrap css definition in media query
please refer to: http://www.w3schools.com/css/css_rwd_mediaqueries.asp
Quite a helpful site.
I just changed my mind and now I would like the have 3 bricks wide across all media. (web - iPad - mobile)
Do you have a bit of css for this? I won't change my mind again. Promise.
Thanks, that works perfectly!
