turn off "pop up" feature in work
in FatMoon Posts: 136
Hi Guys,
Where can I turn off the "large image" pop up feature like when you click on an image.
see link and attachment.
http://bumsch.com/work/book-mockup-2/
    First thing: why you would want that?
    General answer would be to disable lightbox http://apollo13.eu/docs/apollo13_framework_theme/#!/theme_lightbox
    But solution depends on what you need.
    Hi Air,
    I went to: Customise -> General settings -> lightbox settings and turned of lightbox settings.
    elas that didn't help. :) please advise.
    Thx! Vincent
    edited October 2016 Posts: 10,970
    Sorry, my bad. I didn't notice it is from Visual Composer. You can reverse this change.
    I see you used here media grid element from VC, and it doesn't have option to disable it. You can try this solution however http://stackoverflow.com/questions/37179025/disable-prettyphoto-wordpress-visual-composer
    Or instead of media grid use single images.
    Hi Air,
    Thanks for the offered solution.
    When I stick below piece of code in my (Fatmoon) functions.php (overwritten via ftp) my site won't load anymore.
    Should I be patient? is that a server thing? Or did I not use the right code?
    function remove_vc_prettyphoto(){
    wp_dequeue_script( 'prettyphoto' );
    wp_deregister_script( 'prettyphoto' );
    wp_dequeue_style( 'prettyphoto' );
    wp_deregister_style( 'prettyphoto' );
    add_action( 'wp_enqueue_scripts', 'remove_vc_prettyphoto', 9999 );
    I believe it produced PHP error. Please show me screen shot of source of function.php
    Hi here you go.
    1700 x 1134 - 263K
    and this is where it is placed
    1236 x 1234 - 316K
    Well code looks good for me, it might be different conflict. Please enable debug mode https://codex.wordpress.org/WP_DEBUG
    Next add this code again, and come back to me with error that you will see when opening your page :-)
    Thanks so much for your patience!
    after debug tweak it says...
    Parse error: syntax error, unexpected '}' in /home/vhosting/f/vhost0029702/domains/bumsch.com/htdocs/www/wp-content/themes/fatmoon/functions.php on line 21
    O yeah, debugger is right :-) Remove this } from line 21
    Cool. I just did that and now the site does load but it still shows me a pop up. (this time without the frame around it)
    Any ideas?
    Don't worry almost weekend. ;)
    visible when you click on an image
    Lightbox is disabled like you wanted(it now opens image in browser), but:
    Air said: First thing: why you would want that?
    You didn't answer me that so I didn't know if you want to disable lightbox or disable option of it being link.
    As removing link from here is not possible without editing VC code I will cite my post ;-)
    Air said: I see you used here media grid element from VC, and it doesn't have option to disable it.
    See ya on Monday.
    Hi Air,
    Thx!
    that's a pity. I used media grid because I couldn't load multiple images at once and I wasn't able to place pictures side by side. Or is there a way to adjust?
    If you want to put them side by side, you will have to place it in different columns for example.
    Unfortunately I don't have control over what VC implements, so we have to use what they give ;-)
    Okay that's clear will have a look.
    Thank you!
