Tags in posts
in Photon Posts: 48
Is it possible not to use tag h2 in this place (please look to attached files).
Thank you.
    Here is next image
    1581 x 594 - 317K
    Could you post link to that site, cause I am not sure what element is it on your screen shot, as you wrote that these are tags element.
    Thanks for reply, i will give you link a little bit later.
  • edited December 2016 Posts: 48
    Here you can see it.
    [link removed - author request]
    I just think that tags (h1, h2...) should be used only in posts (content) for better seo.
    What do you think of it?
    On my website this tag is not relevant to the article, he repeats when showing all articles.
    Thank you.
    Well, i found h2 tag in single.php, it dubbed tag h1 in post. But i really can't find where to edit to change tag h2 here (see the image). Air i hope you will help me.
    Thank you =)
    1607 x 540 - 207K
    I don't see any posts in your blog. I believe you should disable cache or refresh permalinks. I am now not sure if you mean subtitle in blog or in single post.
    Also I see you have already changed h2 to strong.
    photon-a13\advance\utilities\layout_parts.php line ~517
                //subtitle
                if($subtitle_on){
                    echo '<h2>'.$subtitle.'</h2>';
    Oh..thank you.
    Yes i have changed it and did't saw the result.
    Now i see it. Maybe problem was in cache.
    edited December 2016 Posts: 10,970
    I still don't see any blog post on [link removed - author request]
    However main issue of topic is solved now?
    Air
    Yes. Thank you. Tag h2 chaned.
    I haven't published post yet..
