Mobile version on the site
edited October 2016 in Photon Posts: 48
Website on my mobile phone loads very slowly (i can'tuse it on the cell phone).
Сan you advise something?
On my slider i have 1 gif file (2.3 mb) + 5jpeg files (0.8mb). Is it possibly to make the versions of these files only for the mobile version of the website. To reduce them in size, and that they only opened on the mobile phone.
Is it possible to disable music on mobile website?
Attach a report from Google.
I use wp super cache.
Thank you, Goodluck.
Post edited by PavelT on
    PavelT said: Is it possible to disable music on mobile website?
    Music doesn't load on mobiles until user request it - mobiles are made that way.
    PavelT said: On my slider i have 1 gif file (2.3 mb) + 5jpeg files (0.8mb). Is it possibly to make the versions of these files only for the mobile version of the website. To reduce them in size, and that they only opened on the mobile phone.
    Nope, sorry. Mobile is also very broad term, but anyway theme doesn't have such feature.
    Anyway if you use slider on your page then all images in slider are loaded after page is already visible.
    Ok. thank you.
