Hello
i'm having some troubles with landscape view of fatmoon.
On iphone 7 and 6, when u go landscape the text becomes very small. How can i fix this?
Also, easy question: what is the animation of the portratit in the demo? (the one u got when u pass the mouse over the man)
Here the lin to my website: www.marcellovercesi.com
Thank you!
You site is offline. Probably you have maintanance mode so you see your website and im not
But i have an idea how to solve your problem. Check the screenshot: http://nimb.ws/uCO1E9
There are buttons to change the slider content in different resolutions.
I hope it helps.
With Regards
looked at your screen but the problem is on iphone/landscape view. The button only allows me to set the iphone view, not the landscape mode. Any other idea on how to fix it?
PS: Now the website is live, you can check it
Im sorry for the late reply. Your message was lost somewhere in the new topics.
I need to know if you were able to fix your issue. Please let me know
With Regards
no worries No, the issue is still "open".
After that we for sure find a solution
Rememebr also that Revolution Slider need to adjust the text size to the size of the browser.
