I am unable to customize the theme as the save & publish does not work and the site does not appear in the display pane. I have imported the demo assets for Hudson. I have tried deactiviating all of the plugins one by one and then all at the same time but it does not resolve the issue. In addition I was sent the template with the redux framework in development mode and I am not certain if this is creating the issue. I am not at all a developer just a marketer.
Please send me a private message with login credentials to your WordPress installation - I'll immediately start to investigate what happening there.
I have the same problem. Can you help us?
Thanks,
Sergi
this particular issue was caused by a hosting, which was using obsolete PHP version. Make sure you have PHP 5.3 or newer.
without it I can just guess.
https://codex.wordpress.org/Editing_wp-config.php#Increasing_memory_allocated_to_PHP
http://apollo13.eu/docs/apollo13_framework_theme/#!/issues_importing_demo_data
Yes I changed memory limit in wp-config.php: 96M seems fine but with 128M the site stops working entirely (blank page)
If 96 works, then go with it :-)
Fine, but I still cannot customize theme settings.
I deactivated 5 plugins (look at screenshot) and then the customizer works fine.
So Deactivate them, and then activate one by one and check after each step if customizer is working - so you will know which plugin is breaking the customizer.
The problem was caused by IgniteWoo Updater, a plugin which is needed to update WooCommerce Wishlists Pro, so I think it can stay inactive and I will activate it only when an update is needed.
