Please resolve Album issus !
Very easy !
Short "DESCRIPTION" - Album will load normaly : http://bykiethoney.com/album/puca/
Long "DESCRIPTION" - Album will load if scroll down : http://bykiethoney.com/album/come-back-to-basic/
    Hi there:-)
    Are you continuing your topic form here http://support.apollo13.eu/discussion/4445/my-album-do-not-show-automatic#latest ? Cause you stopped responding last time. If yes then please reply there and also reply to my private message regrading that case.
    Your links doesn't work(I can't see your albums), as your page is probably set in maintenance mode.
  • edited December 2016 Posts: 10
    Yes, Im so sorry because I cant find that topic !
    maintenance mode turned off ! You can see everything now :D
    Post edited by tonngodoc on
    OK, I understand. I can't recreate same bug on my installation, so if you don't mind I would want to do it on your site.
    Could you please send me temporary access to your WordPress and FTP so I could check there what is going on? Send it here on forum via private message(click on my nick, in top-right corner you will find option "Message"). In message please attach LINK to topic it applies to.
  • I think if you have a very long description, It must be longer than web browser to much then you will have same bugs.
    Nope, it is not enough for this bug. I have album with long description that I work all the time on, and it loads fine. I will try to use your data to check this issue.
    Thanks for data. Issue was indeed connected to height of content in sidebar. My personal album wasn't suffering cause of this issue just by luck:-S
    Thanks for help, fix will be added in next update.
  • Thank you very much !
    My client didn't known and said "Oh, My site is loading too slowlly". hahaha
    Kinddest regards !
    My bad :-) Thanks for patience and help!
