rounded password input field on mobile
in FatMoon Posts: 136
Hey Guys,
On mobile.... when clicking on a locked item at the bottom of the homepage
http://vincentdevries.com
I get a rounded input field (should be sharp corners) and Submit is not centered. see attach
Can you help me out with some custom css?
    Is this still happening? I can't reproduce rounded input.
    Please also write more about the device and browser you use on mobile device
    Not sire if I sent you the attach
    here goes
    it happens on the home page page, last work item on an iPhone 6 in safari. (not other size formats)
    750 x 1334 - 72K
    edited December 2016 Posts: 10,970
    I don't know about rounded input, might be something specific to iPhone, however submit button has not enough spaces in this resolution. I will try to add some better styles for it in upcoming update.
    Maybe full width button under full width input? What do you think?
    Maybe it has to do with the (messy) css I added into the css field?
    I added below to make the corners sharp and change the colors. There's probably code that doesn't need to be included?
    input[type="submit"]{
    background: #000;
    display: inline-block;
    border: none;
    box-shadow: none;
    cursor: pointer;
    color: #fff;
    font-size: 11px;
    font-weight: bold;
    text-align: center;
    text-transform: uppercase;
    text-shadow: none;
    line-height: 38px;
    white-space: nowrap;
    height: 40px;
    padding: 0 30px;
    webkit-border-radius: 0px;
    border-radius: 0px;
    input[type="submit"]:hover,
    input[type="submit"]:focus{
    background: #0a5de6 none;
    color: #fff;
    "Maybe full width button under full width input? What do you think?"
    I would prefer input field and button on one line
    vncnt said: I would prefer input field and button on one line
    Maybe you are right, try such custom CSS:
    @media only screen and (max-width: 600px) {
    .post-password-form input{
    width: 50%;
    .post-password-form input[type="submit"]{
    width: 49.99%;
    About input, it looks that it is iOS thing, I will check what can be done.
    OK, it looks that iOS rounds corners by default and we didn't overwrite this behavior up to this day.
    Add this to fix it, or wait for update :-)
    input[type="text"],
    input[type="password"],
    input[type="search"],
    input[type="email"],
    input[type="url"],
    input[type="tel"],
    input[type="number"],
    input[type="range"],
    input[type="date"],
    textarea{
    -webkit-border-radius: 0;
    border-radius: 0;
    Nice work! Will insert custom css soon.
    Cheers!
    Yes that works, thx!
