Post List Filter Glitch
Hi there!
The Post List Filter Feature is acting strange. On some categories it only filters the first post (in my example videos / dies & das) or nothing at all (unterwegs).
If you call the categories directly everything shows up fine. I've tried to get rid of some child categories but that didn't to the fix. Do you have any ideas on that? Thanks a lot!
    It works fine. This filter filters only loaded items. When you enter specific category on other hand, only items from that category are loaded.
    So it is not the same as links to categories.
  • Ah okay, so it grabs the first 10 posts and mine are simply too far in the past. Got it. Thanks for your help.
    Yes, exactly. Might not be too useful in your scenario, so feel free to disable it.
