Product and Shop Image size issue
Hello - I'm having an issue with the images of product layout on the listings and single product pages. On a desktop or laptop there not in proportion and clip the images. Also on a mobile device they are not displayed correct and align left or right in zig zag effect and not symmetrical. You can view live on artisancoffee.cn or see the attached images.
Your documentation says "Theme uses script that auto scale images so it doesn't define any sizes of images."
    Artisancoffee said: Your documentation says "Theme uses script that auto scale images so it doesn't define any sizes of images."
    Yes, but WooCommerce has its own image settings. Text you cited only talks about places defined by theme layout.
    So to change images in WooCommerce follow this instructions
