Well link to this page would help a ton so we could see what HTML is there exactly, and could target it with custom CSS. In other case use Visual Composer options to center it.
On website you just fixed for me is it possible to have a rounded pink button and slightly bigger please? Same as attached screen shot but pink instead of blue?
Right now on the Starter theme this option is enabled: http://nimb.ws/JMiaRb that means that the mailchimp use the starter CSS styles so you can change the colors in the settings here: http://nimb.ws/naCAjd .
Like you see there is no option for size so you must do it using the Custom CSS, try this one:
I made everything bigger but if you want you can change the font size, paddings and height but remember if you change the height you must also change the line-height eg.
height: 56px; line-height: 58px;
P.S The same story you can implement in the Agency Theme, just enable the option from my first link in the mailchimp tab.
With Regards
Thanks.
You have "centre" and it should be "center"
With Regards
Thank you again for fast reply.
Could you please tell me how to edit CSS for this so I can do it on my Starter site? I need to centre my "sign up button" on Starter site.
This pink:
#e5055d
I know this is a lot to ask but I'm almost finished.
Thank you.
Like you see there is no option for size so you must do it using the Custom CSS, try this one: I made everything bigger but if you want you can change the font size, paddings and height but remember if you change the height you must also change the line-height eg. P.S The same story you can implement in the Agency Theme, just enable the option from my first link in the mailchimp tab.
With Regards
How do I add more padding above the button so there is space between the enter email field and button. I will need to do this on Starter as well.
Thank you very much again.
For this particular form this custom CSS should help: With kind regards.
Thanks for the advice.
