Hi, In my hidden side bar I have a social sharing widget to save the page that the user will be on and share it on social media. What I would like to do is add a button on each blog post and portfolio page that says "Share this post/page" or whatever, then on clicking it, the hidden sidebar appears. From my understanding this link is generated with javascript so I understand its not a simple hyperlink, but it would be great if you can tell me the script used to open it so I can either create a custom button with html and js, or somehow add the trigger to the theme styled button.
If you know JS you can write simple trigger that will do
.click()
on button that open hidden sidebar. Just add ID to you button and target it by this ID.Do you have any JS/jQuery knowledge?
Please let me know If you know a script that will work, then I can add it.
Thanks again
Here's how it looks if you are interested: https://cl.ly/0z3U01090Q0m/Screen Recording 2017-02-20 at 01.45 pm.gif
