I'm using the Odessa and Verona version of the theme on two different sites - For some reason the logo disappears on the Odessa theme - It worked before but now and old logo shows up - or none at all(?) I wanted to have a bigger version of it but could not change the css successfully - so I deleted it and now I cant get it back. Some hours are spent on this. How do I get it back, make it larger and position it good with the menu?
Does it only happen on homepage or on every page? Odessa demo uses header color variants so this is probably source of issue.
Check this answer http://support.apollo13.eu/discussion/comment/19373/#Comment_19373
Also if you could show link to your site I could verify it faster what is going on.
Thanks for quick response and a good theme.
If I could see your page I could answer you precise, as it depends on header variant that you use.
However generally if you upload bigger logo, and reduce logo top and bottom padding you should get what you want. In some header variant logo width is restricted to 200px what limits also height.
1. You can try such custom CSS to increase logo: 2. -
3. Customizing ▸ Header settings ▸ Main Menu ▸Hover effect
4. -
5. Customizing ▸ Header settings ▸Type, variant, background ▸Disabled, show only default header(not fixed)
Your ideas break how header is designed in our theme, so not all is possible with simple custmization.
Menu is centered relative to logo, and submenu is displayed below edge of header.
I can't give you CSS that will change it as it brings with it self too much consequences.
If you like do it to your own responsibility.
