I just updated Wordpress to 3.5 and then my images for my home page album stopped showing up.
I looked at general settings and it's set to a specific album but it's just the loading graphic and no images or thumbnails are coming up.
Temporarily I set the home page to use the album as a background. But this does not allow me to have thumbnails across the bottom.
I need to resolve this quickly. How can we move forward. I need help.
What is not working is the Main Settings > Front page settings > Select Album
The I chose the album and no thumbnails or images load.
You have posted in close time interval ;-)
If you won't do it in 10 minutes from now ,then I am going to sleep, so you can try to do it in about 10 hours from now and then post, so I could check.
EDIT:
check if this solution also works for you http://support.apollo13.eu/discussion/662/spaceship-start-album-no-function#Item_4
Please keep me advised when there is a fix for this.
Thank you.
Any thoughts?
Thanks so much!
I Hope we will solve it:-)
Thank you.
I will write here when update will be available on ThemeForest.
I asked before: By same network I mean for example network in office.
I admit that this very odd what is happening, but I just can't recreate your issue on any browser, and this why we can't get any further. Please tell me what about other browsers? Is it good on them?
With regards and happy new year!
To further answer your question: Yes, I have looked at 4 separate networks (my home, the site owner's network, my husband's work network and a developer friend's work network). All separate networks have produced the same photo slider glitch where the photo appears for a split second and then is gone.
A bit more detail: Based on the screenshot you sent me, it appears you're taking a look at the first slide of the gallery, which I see also. It's the following 11 or so slides that are acting glitchy.
I'm attaching a screenshot of http://clarkegalusha.com/?album=improving-bernice. In this photo slider the photos are acting a bit differently than the other albums (still glitchy, but easier to screen capture). Maybe it will help clarify?
Also, the site looks great on IE, Safari and Chrome on all the separate networks I've tried.
Thanks again for looking into this. I really appreciate your time.
Hmmm you know, I maybe know what are you talking about so please try to update theme! There was issue in recent version of firefox with
position: fixed
elements, and I tried to find out what made our other them so lagging in album view. After some testing I found it that "complex" elements withposition: fixed
was having problems, and albums are just such elements. When I was preparing last update I faced same issues with Spaceship, but I made some changes and it started to work. Also I have latest version on firefox(17.0.1) and I am not seeing this issue. Maybe it is now hiding from me, but I believe that update should fix it!With regards.
Regarding the update...do you have any guidance for how best to install the updates.? I want to make sure I don't overlook any steps. My client is getting quite anxious for the fix. He just received an email from a peer saying that all the photo sliders are really glitchy and not viewable (Firefox on a Mac).
Thanks again!
Hope this will be solved now!
In the meantime, I've turned off the auto play on the photo slider for each album. This does enable the user to see the slides, they just have to advance to the next slide manually using the left/right arrows. We'd love the auto slide back though
Thanks again, and again!
J
Also you should use plugin for update, just as explained there, cause of your screen shots it looks like you tried manual update. Read again please and follow instructions. Hope this time you will get it done :-)
Wish you best luck:-)
