Hi, how can I add other social Icons to Hypershot( I.e: Instagram) ?? And how Can I become it more bigger? (I can modify the size of "follow" but not that icons)
Size of icons shouldn't be changed. However if you really need use this CSS
.socials .slide a{ height: 16px; width: 16px; }
This is current size. Set both sizes to same value. Icons are 24x24px to look good on retina displays, so if you will higher this up they could look worse there. ----
Adding social icon Drop your image of social icon to one of icons set in images/social-icons, name it instagram.png. Go to advance/options.php line ~1184 and below
Size of icons shouldn't be changed. However if you really need use this CSS This is current size. Set both sizes to same value. Icons are 24x24px to look good on retina displays, so if you will higher this up they could look worse there.
Adding social icon
images/social-icons
.Go to
advance/options.php
line ~1184 and below add With regards.I prepared the icons (Instagram & 500px) that you can add according to the instructions by Air.
Best Daniel
