'HomePage look' settings creating errors on Portfolio page?
edited December 2011 in Airborn Posts: 12
So basically I've come across this error, when I change my options in the 'Homepage look' (see image) it creates a weird error for my portfolio page? (see Image 2) I was wondering if anyone else has had this issue and if there is any way around it?
Thanks...
    Yes, we sorted that in here, but I don't remember what should be added for fix, cause it was month ago. Anyway I will send you on e-mail file that should fix this, but backup file that you will overwrite.
    I have a same trouble !
    Can you help me please ? Thx
    wp version : 3.3
    Theme version : 1.2.6
    This file should fix it. But backup your version first. If it wont fix, write here :-)
    zip
    zip
    taxonomy-skills.zip
    2K
    Great support ! Thanks ;)
