Limited at 93 images per album?
edited June 2013 in Hypershot Posts: 2
how can I add more than 93 images per album?
regards Henning
Post edited by boogs on
    Hello
    There is no limit in images per album. However some users hit similar limits on their servers. It was once 78 images, but also other numbers. Unfortunately I couldn't recreate such issue so I don't know what is blocking adding more images.
    Have you tried adding single image with Add next image or video button?
    yes I tried to adding single images with "Add next image or video" button, but it still doesn't work.
    Can it be a problem with the "php.ini" file? "post_max_size" or another setting?
    regards
    Henning
    To be honest I don't know but it could be that. We had some informations about reaching limit in the past(78 for example), but I could never test their servers so I didn't find cause of this issue. Also couldn't recreate this issue on my server.
    If you find out anything please tell me:-)
