There in 'terms' => array( 'other','video' ), you add slugs of categories you wish to exclude. I added 'other' and 'video'. Slugs of categories of portfolio you can find in Admin->My portfolio->Portfolio Categories in column slug.
To exclude category in main portfolio page you do the same but in file taxonomy-skills.php in line 26(around).
To hide category in list of categories(above your portfolio projects) easiest way would be to hide via CSS. For example we want to hide category with slug 'other' so we add such CSS:
Thanks a lot. But the CSS solution isn't really useful. If I assign two different categories to a single portfolio item and exclude one, it doesn't show up under "All".
2. This point I don't understand, cause I don't get what you would like to achieve. Some live link with description would tell me more(where should it lead? do you want change name or slug also? somthing like that ;-) )
Is is not an easy task but lets try:
We will have to edit query for portfolio. For front-page we edit file front-page.php, find lines (around line 103): and change them to: There in 'terms' => array( 'other','video' ), you add slugs of categories you wish to exclude. I added 'other' and 'video'. Slugs of categories of portfolio you can find in Admin->My portfolio->Portfolio Categories in column slug.
To hide category in list of categories(above your portfolio projects) easiest way would be to hide via CSS. For example we want to hide category with slug 'other' so we add such CSS: Hope that helps.
But better edit that file you have created and delete those lines: 2. This point I don't understand, cause I don't get what you would like to achieve. Some live link with description would tell me more(where should it lead? do you want change name or slug also? somthing like that ;-) )
Good job btw ;-)
