need help - on my hypershot theme the blog comment does not transmit any comments? you can write a test but then it writes : "pls. correct your input"? does anyone know what the problem is? I use the plugin SI Captcha.
Anyway if you read topic I linked you then(I hope you followed it): 1. Have you tested with switching off plugins? 2. If yes show me please live link to issue page.
I think you use different plugin then one that I recommended. And I don't know how it works so can't help you(language in screen shot is also issue:-) ).
now I have the right one - and :-) everything works fine! Thank you so much for your support & your patience ... love my new homepage ;-) and of course your theme!
I asked before and if you ignore me again then I wont reply any more to this topic. So have you? Tried it?
And for anti spam we added support for this plugin http://wordpress.org/plugins/captcha/
You named this topic so I believe you can tell by your self does your new question contain in this topic area :-)
Here you can see how plugin I mentioned earlier should be configured http://apollo13.eu/docs/beach/#!/plugins_recomendations_captcha
It is just explanation how to configure plugin, cause I forgot to add this to Hypershot documentation:-)
