I updated Wordpress. Now I cant modify page in visual composer. Is URGENT!! Can I send you login details to check? I want to add 3 columns, in each column to be one text separator, and text content. I cand add Text Box because appear again some column shortcode etc
My website:
http://jnyhost.com/gethappyjuice
For moment I still cant update Visual composer from 4.0.3 to 4.0.5 and after wordpress update I see that a new version is for Visual composer.
Fix with new builder will be ready in few hours.
You can't update this plugin as it is embeded in our theme and it is commercial plugin. It only gives misleading info about update:-S
