Menu disappears when using Ctrl+F
edited June 2014 in Beach Please Posts: 111
Hi!
The (sticked) menu on the side disappears when I use Ctrl+F. It only happens when I scrolled down a page.
See attached file.
    Header goes back to top, cause it doesn't have enough space to show all the content without cropping some off. If you would have taller window and hit ctr+f, or smaller window you will see from start that header goes to top page. It works as intended, you just hit "edge case":-)
    I see… :)
    Gracias!
