1. Can you see this issue also in our demo http://superior.theme.apollo13.eu/ Yes, with your demo happens too Tested with Iphone 5, ios 7.1 2. Have you made any changes in code/CSS? Not yet 3. Live link please. http://nuevo.linc .es
(Copy and paste the link and remove the space. Sorry to do it the complicated way, but i dont want nofollowed links to this domain)
roquelage said: Copy and paste the link and remove the space.
It is ok, but please link to page where I can see issue, either on our demo or your page. You said it happens on subpage but I couldn't see it there. Screen shot would also help to know what I should be searching for. Thanks:-)
Not yet
Thanks!!!
So i guess, problem is solved...
I saw the problem at your website navigating internal pages of shortcodes, but as i said, is fixed for me
Thanks!!!!!!
Same snapshot will fit
https://www.dropbox.com/s/a0yorcjlfko5m67/Captura de pantalla 2013-12-24 15.38.08.png
It seems as it loads correctly the menu, and suddenly, the menu block moves to the left.
If you switch the iphone to horizontal, and switch it back later to vertical again, after 2 switches looks perfect.
Im using iphone 5, ios 7.1 with safari
For me treate it as solved, now im not having any issue
Best regards!!
Im detecting again this issue but is happening only in iphone 5/5s
I tried to emulate the problem via responsinator and everything looks fine
Tried the menu also with galaxy S4, regular LG phone and iphone 4 and it looks ok
I would definitely give up on iphone 5, but my bosses were who noticed so im forced to fix it.
Please, could you provide any advice on the topic? link: http://nuevo.linc. es
Thanks!!
Best regards
if anyone experiences the same issue....
overflow hidden to access touch under 480px
Best regards
Thanks for solution, but again I missed what was the issue ;-) So it can be seen on our demo on Iphone with iOS 7.1?
SOLVED
Thanks Air
