Hi there,
In the create a Gallery page using the Upload multiple files button I can add multiple images but I can't select multiple images to insert. I have massive galleries to upload and cntrl / cmd etc don't work
Please help! it's for www.dhg.co.za
I don't know how advance you are with menaging Wordpress so please check this video to see when you should hold ctrl key.
Hope that helps.
http://support.apollo13.eu/discussion/2354/album-multiupload-does-not-work-properly#Item_2
