Hi a while ago I added this code to my css to make the background hover on main menu white
.top-menu li:hover, .top-menu li.current-menu-item, .top-menu li.current-menu-ancestor {
background-color: #FFFFFF;
Now when you choose submeu item the main item is white as well - I cant seem to find where to change this.
here is my link - select work and the select logo - then watch work disappear.
http://levelcreativ.comthanks
Yes, you overwrite default bg-color of marked items and that is why it happening. You will have to add such custom CSS Please comeback to me and tell if it works for you.
In your case I think CSS should be like this, so it will be good in every scenario: I have tested it and it works nice in your case.
Sorry for not testing this earlier.
