Transparent header not working in IE9
edited July 2014 in Superior Posts: 17
So I've changed the background-color for #header to transparent.
Underneath the header I have a fullwidth layerslider with a big image in it, positioned with a negative margin-top, so it actually goes UNDER the header.
With the #header background set to transparent - the image shines through underneath the header, which is what I wan't.
This is in Chrome. However, in IE9, the only results I can produce is:
The body bg-color shines through the header, not the layerslider. It's like IE cut right through layerslider and goes directly to the background for the whole body.
Here's a screenshot from chrome, followed by one in IE.
What's going on here? Why won't it work in IE?
    Solution, put this in the custom CSS:
    #mid { overflow: visible; }
    Man I'm sorry, haha! I've spent an hour trying to solve this problem, and of course I find the solution 30 seconds after writing here! I believe this happened sometime before too :D
    Ah well...
    minor9 said: and of course I find the solution 30 seconds after writing here!
    This happens all the time:-) Sharing your problem brings your mind to better solutions:-)
    Thanks for info and topic.
    Have fun:-)
