I have loaded images to display on my homepage slider (LayerSlider), and created a page called Home, which is chosen as the home page on the Customize screen. I have added the slider element using the Visual Composer but the slider still does not want to show. What am i doing wrong? Please help
Is other content from this page Home showing up on your front-page?
If you will still have problems doing it then I will try.
Good luck:-)
If not then, could you please send me temporary access to your WP so I could check there what is going on? Send it here on forum via private message(click on my nick and there you will find option "Send Air a Message"). In message please attach link to topic it applies to.
