No Spacing Between Name and URL In Blog Bio Area
edited August 2014 in Superior Posts: 66
I have my bio set up which appears at the bottom of every blog post (ex. http://www.alexnavas.com/know-your-why/) which I love. However, there is no spacing between my name and the URL to my site so it reads: Alex Navas(http://www.AlexNavas.com)
Notice the lack of spacing between the last letter of my name "s" and "(" that is in front of the URL. Where can I add the proper spacing?
Also, is there a way to set the bio URL to open in a new window? I have another site with my bio but when people click, they leave that site and come over the my bio url.
Thanks for your great support.
    To add space and open in new window go to single.php line ~54 and change
    echo '<a href="' . esc_url($u_url) . '" class="url">(' . $u_url . ')</a>';
    to
    echo ' <a href="' . esc_url($u_url) . '" class="url" target="_blank">(' . $u_url . ')</a>';
    Hope that helps:-)
  • Worked perfectly. Can you include this in the next update? Don't want this to be overwritten when I update
    I can add space, but not opening in new window. Just copy whole single.php to child theme, and if you are using child theme it will use this modified file instead of original.
  • Ok, perfect. Thank you for your help.
